hi newly got a 95 and want to do a oil and filter change.. runs grate and has 17000 miles on it, no leaks, do i go for 15/40 or 10/40?? and what is the correct torque for the sump bolt? thanks matt
I dont know the torque setting, basically hand tight then a slight snick on the spanner. If it doesnt leak its fine
Worth changing the front and rear diff oils as well, rear is very simple, front is a bit of a faff as you need to remove the underplate and have to be a bit quadruple jointed!
Is it a Prado, if so use semi-synth diff oil with lsd additive, you can put that in the front as well.
Roughtrax have an offer on at the second with Toyota 10/40. I bought 20 litres. Couldn't resist really. Not because I feel it's better than anything else but at the price it was significantly less than even my local parts warehouse.
I got 20L for £54. Frank would be proud. I don't think I have ever bought genuine Toyota oil before. I'm guessing they have their own well and everything.
Halfords do some bonkers offers sometimes. You just have to check their sire regularly
4L of Carlube Triple R 10/40 SS £7.75 (inc vat) from JTF wholesale when I changed mine in October. That's the cheapest I've ever seen it. Just a case of being in the right place at the right time to catch these deals. When I last bought Toyota branded oil 3 or 4 years ago it was Mobil according to the parts guy.
