Lorin
- Mar 28, 2010
Currently in Hungary having completed a 10 day offroad tour with World 4x4 in Croatia and now have a slight oil pressure issue.....
2 days ago whilst going up a hill in 3rd gear the oil pressure dropped off the gauge. Stopped, found oil level was low (will tackle the oil burning issue and blue smoke when I get home!), so I topped up the oil to the correct level.
Now the oil pressure is low - never getting much higher than the first marker and doesn't respond to the engine being revved which it previously did (pressure increasing with engine revs and then dropping when revs reduced). Also, when I turn the engine off the oil pressure gauge does not just drop to 0, instead taking a while for the pressure to drop....
My thoughts are that the oil pressure sensor may simply be playing up as the engine is otherwise running fine. Any thoughts/ideas/advice would be greatly appreciated.
