Rob
have a look here, it tells you how to install the lift and caster correction http://www.sleeoffroad.com/technical/tz_ome.htm. basically for the lift unbolt anything that may get overstretched like brake lines and breathers and then unbolt the shocks. be careful with the rear top shock bolts, they can be a PITA to get off if corroded.
