OME Steering Stabiliser
Hi Dennis,
Should be a straight forward swap out.
Mobile: 07971 540362
On Mon, 24 Jan 2005 11:24:43 GMT, Julian Voelcker
Hi Dennis,
Just curious: Does the OME stabiliser for LCs have several holes at
the closed end of the round sleevee over the shaft, like the OEM part?
If not, I'd recommedn drilling them - when the sleeve gets packed with
sand and mud you will have a problem with turning the wheels full
lock.
Rgds,
Roman (London, UK)
'92 HDJ80
Thanks Julian and Roman for the info,
Roman,
"Does the OME stabiliser for LCs have several holes at
No, but I'll drill some - thanks for the tip. I've got a guard that attaches
to a bull bar, but the '91 1HD-T bull bar doesn't fit the 1HD-FT '96 version
(the front wheel arches on the 1HD-FT are too wide).
Julian,
"Should be a straight forward swap out."
I realised I need a 2 leg puller to get one end of the steering damper off.
On the internet there's a good website for tools: www.tooled-up.com -
hopefully a 100mm 2 leg puller will do.
(It's about time I started filling up the toolbox!)
Rgds,
Dennis, London UK - at last it's snowing, albeit very little
'91 1HD-T
'96 1HD-FT
The Royal Bank of Scotland plc, Registered in Scotland No. 90312. Registered Office: 36 St Andrew Square, Edinburgh EH2 2YB
The Royal Bank of Scotland plc is authorised and regulated by the Financial Services Authority and represents The Royal Bank of Scotland Marketing Group. The Bank sells life policies, collective investment schemes and pension products and advises only on the Marketing Group's range of these products and on a With-Profit Bond produced by Norwich Union Life (RBS) Limited.
This e-mail message is confidential and for use by the addressee only. If the message is received by anyone other than the addressee, please return the message to the sender by replying to it and then delete the message from your computer. Internet e-mails are not necessarily secure. The Royal Bank of Scotland plc does not accept responsibility for changes made to this message after it was sent.
Whilst all reasonable care has been taken to avoid the transmission of viruses, it is the responsibility of the recipient to ensure that the onward transmission, opening or use of this message and any attachments will not adversely affect its systems or data. No responsibility is accepted by The Royal Bank of Scotland plc in this regard and the recipient should carry out such virus and other checks as it considers appropriate.
