spackrackman
- Mar 7, 2010
recently someone mentioned a good online store for hoses and fittings. I am a bit lost here and may end up in Pirtek with a pile of bits to see if I can cobble something together.
Anyway I am trying to take an oil feed from a 3B engine block to a turbo. I need the connection into a spare oil pressure feed in the block and one into the turbo (same thread) and a hose to go in between.
found this on a I h8mud
" I found a place that sells 4AN to 1/8 tapered BSPT fittings... These are exactly what those of us installing turbos need to tap directly into the oil galley on the side of a B/2B/3B engine. "
so two of the above with a braded hose inbetween with a length of approx 15" (be nice to make my on up)
any advice? from someone that might understand what I want.
