Gav missin
- Nov 17, 2015
New toy! !!! Off Road built coming on I think!!!!! 3 80's in the stable now. Ain't life great! !!!!!
It is for some!New toy! !!! Off Road built coming on I think!!!!! 3 80's in the stable now. Ain't life great! !!!!!
Don't need them bits for what I got in mind. Looking forward to this one.Are you going back for the other half ? lol.
Centre diff lock won't operate from dash switch or in low box. Any ideas please gents. Thanks in advanceNice colour for muddin'
Changed the Control box Karl. Could be faulty too I guess. Checked all plugs too. F/r diff indicator lights flash but no cdl. Nothing clicking not relays control box or locker. All looks fairly new underneath4wd control box in the pas footwell.
30a diff fusee ok tooChanged the Control box Karl. Could be faulty too I guess. Checked all plugs too. F/r diff indicator lights flash but no cdl. Nothing clicking not relays control box or locker. All looks fairly new underneath
Yes Dave it came from Garry. Despite the scrapes and grazes it's incredibly solid with virtually no rust and only 200 000 kms on the clock. Planning front and rear winches camo paint job. All lockers work too as a bonus. Passed it's mot with only a couple of advisorys. BEB s planned in the not too near future. Fed up fixing suzukis every week and needed a stronger pay and play toy. If all goes well I'll be taking it to lincomb.I think I have seen this before, did you get it from Gary the guy that breaks 80's? The pictures I saw did show some bits and pieces were missing but would not have taken much to get it back to a 'runner'.
regards
I get them from Garry. Not sure where he gets them Karl.Where do you buy your bebs from Gav?
Any ideas guys. All 3 diff locks operate if 12 v put to them via jumper cable in and out. Cdl will show on dash if it's done this way. Front and back will then operate from the dial switch. However if cdl is taken out via jumper cable nothing. Cdl won't operate from stick in low or from dash switch. Obviously front and rear then won't work. Changed transmission ecu in driver footwell 4wd relay passenger side and the cdl switch closest one to centre diff lock. Now have cdl light on dash but this doesn't go out when put in to high or from the switch on the dash. If I reverse the cdl via jumper cable I lose cdl light. It will not work in high from dash switch either. Any thoughts. Thanks in advance30a diff fusee ok too
I guess they come from me in a round about wayI get them from Garry. Not sure where he gets them Karl.
Cdl switch in the box? Wiring? Better to go to Garry's and swap the stuff off a working one or swap off your other trucks mate.Any ideas guys. All 3 diff locks operate if 12 v put to them via jumper cable in and out. Cdl will show on dash if it's done this way. Front and back will then operate from the dial switch. However if cdl is taken out via jumper cable nothing. Cdl won't operate from stick in low or from dash switch. Obviously front and rear then won't work. Changed transmission ecu in driver footwell 4wd relay passenger side and the cdl switch closest one to centre diff lock. Now have cdl light on dash but this doesn't go out when put in to high or from the switch on the dash. If I reverse the cdl via jumper cable I lose cdl light. It will not work in high from dash switch either. Any thoughts. Thanks in advance
