ONEBADFJ40
- Feb 2, 2015
So I recently went to fire up my FJ and will not fire up at all. Turns over I have fuel pressure but no spark. I'm thinking its probably the ignition switch as all my fuses are good but no power to my distributor. Anyone think of anything else? I would hate to spend the $100usd on a new switch and it not solve my problem and cant return it.
Now for my other question. When it was running before it started doing what I described above. It would fire up no problems when the engine was cold but if I ran it for a while then parked it I would have to wait a hour or longer to restart it. I turn the key when its hot it wont even turn over and my gauges start to climb like it's a bad ground. I'm thinking its The starter being heat soaked with the extra heat from the stroker motor. I even put in a direct start button from the battery to starter and it still wont turn over. But like I said open to opinions and ideas.
