Graham said:Maximum weight continuously?
A column of 40 ton artic's, nose to tail?
On some night time runs down the motorways, there is almost never a car in sight.
If said artic's came up against an obstruction, they would all be brought to a halt ?
No idea really.
I think an artic is 45 foot long?
weighing 38 tonnes?
Gra.
.clivehorridge said:Gross malpractice has occurred here, that's my bet and sadly, nobody will be found guilty. There will be a huge attempt to cover it up.
clivehorridge said:Joints between decks play a big part in this where the load is tranferred from span 1 to span 2
BobMurphy said:I think the Chinese are on a rapid learning curve just as the UK was in the 19th century (Tay Bridge !) and with the same raw commercialism driving it. They will get there.
Graham said:I wouldn't bet on it at all.clivehorridge said:Gross malpractice has occurred here, that's my bet and sadly, nobody will be found guilty. There will be a huge attempt to cover it up.
There has been many investigations over the past few years that I have known about.
Some investigations going back many years to when the project was built.
Already, some body asse will be twitching.
The penalty for hiding away government construction money is death, as it is termed "financial fraud"
There has already been a few , , , , there was one just a few months ago.
Gra.
.clivehorridge said:The deck has survived a huge impact (when it fell) that it wasn't designed to withstand, and appears to have survived in tact.
We've all made mistakes, UK; US; Japan... but we should all be sharing our knowledge and experience instead of each of us inventing the wheel individually. Luckily the UK hasn't had too many collapses (if any) but it has suffered premature bearing plinth failures on deck bearings (the support to the bearings between the underside of the deck and the supporting column crossbeams that the bearings are mounted on). This created deck level differences (the subject of my first message) which meant far higher impact loads as trucks dropped from one deck to the next (anyone who drove the M6 North of Birmingham in the late '80s early '90s will know what I'm talking about).
