Do NOT go with Milner for these seals Toy OEM for sure - read my write-up about rebuilding the front axle in the 80 series FAQ
Gary, the inner hub seal is a different part to the one Justin is pointing out, which is the inner axle oil seal (with correct part no). The inner hub seal is the seal that fits into the "back" of the hub (side closest to diff) and holds in the inner wheel bearing. Part no is 90311-62001 for inner hub seal.
From your description, it sounds like you're after the inner axle oil seal, as pictured by Justin
