[parts discs}
Hi John,
You should be able to just put in the program disk and then run it.It won't
auto start - you have to open My Computer, Open your CD drive and then locate
and run the setup.exe in the Win982k directory.
How far have you got with it?
Mobile: 07971 540362
Hi John,
Hi Julian
The program disk is not the problem at all I think. All I did was open the
files on the program disk and see gcdrom, setup, and setup.lst. Next I
selected the setup and it was installed every thing seems ok, its when I
put disk disk 2 in and open it. It will show me the contents of the disc
but when I try to access the information all it will give me is Windows
cannot open this file, some times it has a warning about accessing program
files that could disrupt your computer, and other times it says to choose
between the web and browse to locate the program. When I try to locate it on
the web windows does not recognise it. When I try to browse I do not see
the program. If and when you have the time if you could program me to do it
right because I hav'nt got a clue what I am doing wrong.
John C
92HDJ 80 1HD-T Ireland
computer dead head
Hi John,
It sounds like you aren't reading the instructions - you load there
other CDs via the software.
I'll email them over again.
Hi John,
