Work has been manic in the second half of the year hence I've been very quiet.
However, I've got a few days off so thought I will get a few jobs done. Photos will follow as I've just got a new phone but...
I've had a pretty bad steering wobble and wobbly brakes.
The steering wobble was the king pin preload not being right after the front axle refurb. The king pin bearings were replaced and the old shims refitted. If you don't know about King pins they are shimmed loose not tight so I went down by about 1/3rd on each side. A quick road test proved it to be 90% sorted so I went down another third. I did all this by eye and feel, no gauges were harmed. If the steering wheel doesn't want to re-centre youve definitely taken too many out. The Rough Terrain kit had a full set of shims in it.
And now for the wobbly brakes.
I bought a set of black drilled and grooved discs from Rough Trax and they seem pretty good. Definitely seems to stop better. Frank will be pleased to know I stayed with Toyota pads. The only fly is that my calipers have seen better days and will be the cause of why my old discs had warped because they were barely worn.
