Olazz
- Apr 23, 2010
Last year when my truck was at JV's, the gearbox came out to do the clutch.
I have a 12v 80' however when the clutch came out, it was obvious that my truck it is running a G/box from a 24v as the 12v clutch was clearly the wrong one.
Couldn't get a 24v replacement in time so JV replaced the spigot and thrust bearing only and put the old clutch back. IRRC the original clutch wasn't badly worn. The truck has ever since the replacement suffered with terrible smell of g/box oil.... That thick, sickly, Sulphurous smell of crude. Nothing seems to have cured the smell and I cannot find whats causing it.
About 1,000km later whilst in Portgual, the truck developed a rattling noise when in neutral and foot removed from the clutch. This is particularly evident when engine and box are warm.
At fist I though this may be the thrust bearing, but if the clutch is depressed the noise goes away, so cant be. I've had no issues with gears or the clutch.
Well today, I took truck out for a proper drive, first time in a loooong time, and when stopped the rattling became quite alarming and very very loud. Even SWAMBO asked whats wrong with the truck, indeed it does sounds like something is very wrong!!
If clutch is depressed then there is no rattling. There is no rattling when driving in any gear and no noticeable difference between 4th and 5th; so don't think its lay shaft bearings.
The smell of g/box oil is still very apparent and no apparent leaks anywhere.
Can anyone suggest any possible cause? Any ideas?
