Sag,
On a '90' the lower ball joint bolts to the lower end of the steering knuckle - where the track Rod attaches. It faces down, with the taper going through the lower wishbone with a nut underneath.
The rivets you are looking at are part of the lower wishbone - not the ball joint.
You have to:
Support the lower wishbone.
Undo the driveshaft from the front wheel hub (but don't try to separate them yet).
Compress the front coil springs to take the load off the joint.
Undo the Track Rod nut and separate its ball joint from the arm that is part of the lower ball joint assembly.
Remove the nut from the ball joint.
Support the wheel hub.
Lower the lower wishbone.
Separate the ball joint taper from the wishbone with a ball joint splitter.
Lower the wishbone away from the ball joint.
swing the steering knuckle out a bit - sliding the drive shaft out of the hub (watch the ABS wiring and Brake Pipe).
Undo the four bolts that hold the lower ball joint assembly to the steering knuckle (good luck with that !).
Remove old ball joint.
Re-build it all with the new ball joint
On the '100' (and '120') the nose of the lower wishbone sits inside a 'stirrup' at the lower end of the steering knuckle. The ball joint is attached to the underside of the stirrup and faces upwards - through the lower wishbone. It is therefore constantly in compression unlike the '90' where the ball joint is in constant tension.
Bob.
