jordan_sorabjee
- Mar 22, 2021
So I have put in a tested ECU, still the same issue. I have also checked the 4WD ECU and that is fine. Does any of your vehicles ABS light up when diff lock is engaged? Mine does, thought it would though if its working.
Next step i need to test the earth and the live, I pressume I would do both by using the Volt settings on a multi meter not resistance. Is that correct? Any advice on this would be much appreciated.
