Project LC80
I'm also fitting an airbag assist system for the rear suspension. When loaded up with the tent and camping gear I could feel the back end was squatting down a bit.
The kit came with a small reservoir tank too, will be able to air up and down the tires easily now.
It's easier to build up the rear quarter panel off the car and then plumb it all in once it's done. I have pre wired up the remaining relays with long pigtails, will be easy to connect up any other systems that might need a relay at a later date.
The power distribution board has 2 sections to it, half is only powered up while the ignition is on the other half is live all the time. So some items that I dont want to run while the engine is off will be powered off the ignition triggered side, less risk of accidentally draining the battery.
The charge relay is a nice system too, it has a switch in the cab whereby you can manually go from auto connected once the start battery is above nominal voltage, to manually connecting the 2 batteries, and also disconnecting the 2 permanently. There is also a high capacity resetable circuit breaker on the feed from the house battery to the inside of the car.
I did also buy from DVS a panhard height correction bracket, as its lifted. Helps reset it to the correct OEM height again.
Can see the airbags fitted inside the springs. I had to remove the original bump stops, and drill out a clearance hole for the airline to go through.
I dont like doing irreversible mods like this, but didnt have much choice. It wouldnt be that hard to weld it up again with a nut in there if I went back to standard again.
Finished off the last bits of wiring and plumbing over the last few days.
Had a test of it all yesterday with the engine running as parts of the system are ignition triggered on.
Fridge powers up, air compressor kicks in and I can raise and lower the back of the truck. I decided to keep the air cylinder inside as I couldn't find a decent place underneath where it either wasnt going to get hit or rattle itself loose. Plus less pipe work now too. I will eventually run an airline to the front for a union there to make filling the front tires easier.
I also had rewired the rear fog light, using (I presume a UK spec) OEM fog light switch. And an additional small led light bar for reversing. Both were working previously, but it was a right cobbled mess of wiring.
My brother got me onto Deutch connectors. Have been using them where I can. So easy to put together, weather tight and can de-pin them really easily. Highly recommend you trying them if your doing any car wiring.
but airbag worth it?
How do you mean are they worth it?
Either I'd have to live with the back suspension essentially being over loaded with the current springs. Or increase the load capacity of the springs, but that would mean it would be terrible unloaded.
To me this gives me better flexibility can have just springs when its unloaded, and then add air to compensate for any extra weight I add. The switches can either fill or vent the bags.
Plus now have onboard air to pump tires up if I decide to air down.
I'm going to do similar .....OME 860 rears then run airbags for towing and adventures loaded with kit .
What make bags did you go for ? some say kevlar bags are best to combat chaffing in the springs .
Bit of an update:
Have completed all the wiring upgrades for the moment.
To summarise, have changed from 24v start to 12v with a new starter motor and got rid of the 24v relay.
This freed up the RH battery to be used as a house battery. I am using the Delta Vehicles wiring kit for the whole vehicle, charging relay, auto resetable cut off switch, 2 distribution fuse boards, one on the centre console and one in the RH rear quarter.
The centre console has been replaced with the DVS mount for a Dometic CDF11 fridge which also makes a great arm rest!
In the back I now have air compressor and relays for any higher power consumers.
Have added led strip lights to the inside if the gull wings and to the ceiling rack.
Have also fitted 2 goosneck lights either side on the inside of the tailgate for cooking etc.
Have added anderson connectors through the RH gull wing to power the lights in the awning and the roof tent plus 1 spare.
The controls for the airbags is on a side panel of the rear drawers with usb charger and air take off for pumping the tires back up.
some nice touches there mate - I particularly like the external Anderson on the gull wing. I've often wanted to run permanent power to the roof for lights and the tent but the thought of drilling into the roof or somewhere else on the body always puts me off.
Thanks!
Has been a while in the thinking and the doing!
Yes I 100% didnt want to drill holes in the body. Doing it through the gull wings I felt OK about.
I would have preferred if they were lower profile, some people in Oz make some nice 3d printed wedge shaped ones. But didnt have the time to wait.
I may in the future modify the panel and weld in a custom piece to support the plugs. I'm a little bit worried about branches etc ripping it off.
The blanking bungs I bought separately and modified the lanyards to hide away under the cover.
Bit of an update:
Some neat work there....
What many don't appreciate is the time spent being neat and tidy with wiring etc pays you back many times over in terms of reliability over time and use....
This build will serve you well for decades with the thought and attention to detail you have spent on it
Appreciate that Grimbo, yes have tried hard to do it properly and to the best of my ability.
With exactly that aim to be reliable and safe for many years of use.
Bit more work on the old bus today, maintenance rather than upgrades.
Changed gearbox, transfer box and both axles oil. All pretty drama free. Loved the fact that who ever did it last time, not me, had fitted the mag plug on the transfer box in the fill hole rather than the drain. Wont be catching much up there!
Also had noticed that all 4 front control arm bushes were pretty badly torn. They were supposed to have be OEM Mr T ones in there, but deffo were not. I have now rectified this with a full set of 6 new bushings. Fitted them in the orientation shown in the PDF.
Greased the propshaft UJs and sliders.
Getting ready for the next Portugal trip!
Hi, I have just replaced my leading arm bushes but fitted the same way as the old ones.
I doubt it makes a massive amount of difference, I guess it just gives a little more flex in a different direction.
If it was good enough for Mr T in the original direction, I'm sure itll still be fine now!
Bit more work on Sunday.
Thought I had an issue with the full beam bulb on the dash. Taking the clocks out of these is such a pain, whole dash apart....
Any way, bulb was fine, turns out led head light bulbs somehow stop the tell tail light coming on, plus I have a light bar that is relayed into the full beam light, the led stopped that working too. Must be too low current draw to activate things? Swapped the bulbs for MOT with the normal candles...
Was also wanting to sort the wiring/plug on my rear diff lock position switch. Turns out I now have an issue with my centre diff lock. After many hrs of diagnosis, dash switch is ok, hi lo, switches are working, relay box is working, pretty certain there is a fault inside the actuator. I can get the motor to drive, by feeding it power, but the internal switches are not working in 1 position.. will have to take it apart and investigate.....
bugger
Few more jobs done yesterday, engine oil and filter change, had only done about 3000 miles since the last one, but it was a year ago.
Adjusted the handbrake for the MOT as it was weak as always.
Passed the MOT this morning with 2 minor advisories, small rust hole in the front inner wing, and bit of play in the steering. It's in the actual column itself, there is a rubber joint part way down, have a new one I will fit at some point. Very happy with that.
Will get the roof tent loaded on today and see if I can get the centre diff lock off and hopefully coax it back into life.
