Project LC80
Centre diff lock rebuild:
Lowered the GB cross member to give me space to undo the 4 bolts holding the actuator on to the transfer case.
From the outside it didnt look too bad, once I finally got it open and all apart it looked like something dredged up from the Titanic. A lot of corrosion and the motor had got a bit hot by the looks of things. 3 of the magnets were detached too.
If new ones were available I probably would have bought a new one as I didnt hold much hope it would work again. Any way, I pressed on, cleaning corrosion off and coating with some grease or WD40. Glued the magnets back on. Being careful to keep them in their original orientation and order.
During removal of the actuator lid, part of the lid broke away on the inside as it was so corroded together. Luckily it was just the part that held the O ring. There wasnt much left of the rubber any more.
Once it was all cleaned up it didnt look too bad, all the parts that were supposed to move now did so smoothly again.
I checked continuity of the position switches on the plate and they were all working fine.
Dry assembled it and bench tested it with a battery, the motor worked and spun the actuator gear round a treat!
I checked it all worked on the car and it did!!
Took it all apart and reassembled it with some sealant to keep the moisture out, gave it a spritz on the outside with some AV30 to help keep the corrosion down and refitted.
Quick test around the yard, engaging and dis engaging the actuator, it all worked perfectly! Well happy with that!
Thanks for the offer of your spare Gav, assuming this one keeps working I should be ok.....fingers crossed
Few last jobs today, we're off to Portugal on the 25th, hence to push to get everything done.
The wiring for position switch on the rear diff lock had rotted away, it was working with a bit of a wiring bodge I did last year before our trip.
I finally got round to ordering the correct housings and terminated repair wires.
I have about 5 spare if any members need some to repair theirs too...
Got the tent mounted and fitted the Toyota wind deflectors, love them so much!!
Too jobs.
Enjoy Portugal, we done a few trips there. Don't forget to try the variety of food. Luis
Last little jobs done on the LC, main one being replacing the brake bose flexi between the chassis and the front axle. Only recently noticed that when up in they air and the axle at full droop the hose was under tension......not ideal.
I ordered an extended hose from Pioneer 4x4 which fitted perfectly and allowed the axle to hang with no tension on the hose. The photo is of it at full droop.
Bled all 4 corners and the clutch for good measure.
Fitted new breather to the centre diff lock actuator to replace the rotten onld one.
Packed all the camping gear and tools, ready for the ferry tomorrow!
Cant wait!
well done. Its not an easy one to fix
Enjoy Portugal. Be interested in hearing how that trip went ; especially if any 4x4 tracks
Hi, it was brilliant, I wrote a trip report on it. Loads of 4x4 tracks!!
Very nice to hear you enjoyed it so many places and routes you can do, we done 3 trips all different, Wikiloc best source for Europe trips.
I'm off this August but not much off-road, family holiday. But food always a big part of my trip. See if I can sort my AC before looking a challenge.
