Found the rear axle input oil seal is spraying oil under the car, I need to swap it out for a new one.
There does not appear to be any lift on the prop so hopefully the bearing is ok.
Can I access it by removing the prop and flange enabling me to pick it out from the front?
Aside from checking the breather hose is not blocked is there anything I need to be aware of?
Thanks in advance.
Thanks in advance.
