MisterCruiser
- May 28, 2014
So I was getting ready to clean and paint my cills for the on coming winter when I seen I have a broken rear passenger axle mount
You can see the damage in the pics attached, it's broken on 3 sides and is partially broken on the remaining front side. The pic with the red circles is the remaining side starting to break. Am I correct in thinking this broken part is referred to as the mounting "Turret" just so I have the terminology correct to make this discussion easier if we're all talking about the same part.
What are my options here:
1 - Is welding this up an option, I can't imagine it being too easy to weld, I can't do that myself but is it even an option to a professional welding person? Is there much to weld to for starters. I'm guessing the axle would need to be removed for said fabrication work at the very least or good a good fabricator do it in situ?
2 - Can this mount / turret be bought as a separate piece and welded in place, does such a piece exist? Could one be made up by a good fabricator / welder person?
3 - Buy a complete 2nd hand rear axle. (risky? Don't know what you're getting regards the rear diff? I don't use the rear diff so would it matter if the rear diff was fecked in the replacement?)
4 - Buy a new genuine Toyota rear axle case from Milner 4X4 and swap my parts over to it. £678 plus delivery to Ireland (how difficult is it to transfer out/in the rear diff from my old to the new case)
If there's any other viable options that I haven't thought of that doesn't involve some petrol and a match I'd really appreciate hearing them
I believe this is a major job, I remember looking into replacing the rear drum brake backing plate / splash plate due to their brake show retaining shoe pin holes being worn bigger making the shoes not sit fully against the backing plate resulting in a crap handbrake and it was a major job. Stripping the driveshafts and axle bearings I remember large presses / pullers involved etc,,, the cost of the back plates was extortionate too, something mad like €5/600 a piece I think they were, need to check. I'd probably have to replace the wheel bearings etc when I'm in there,,, so going the Milner new rear case option could be totaling 2/3 grand by the time all the extra parts are factored in?
Also, what happens if this broke off when driving, would the the body drop down on that corner? Obviously, I'm putting it off the road now but just wondering what would happen.
