- May 26, 2014
just made these for the 100 series, I'm pretty sure most people have a established set up for there 80 by now but if two or three people plus are interested I could make the same for the 80s series, just a thought..
so put the finishing touches to these today, I'm interested on peoples opinions and thoughts good or bad.
they are made from a good quality plywood and come with no finish to the plywood so you can choose your own. be it clear varnish, matt black paint or carpet the choice is yours.
they are very well made with notched housings and bolted direct to the 3rd row seat floor anchor points.
the drawers slide on plastic sliders so there are no mechanical parts that can get clogged up or jam.
the drawers will be sent 98% assembled with only the "wing" brackets and drawer fronts requiring fixing.
the version pictured is £480 posted to your door.
without hinges, magnetic catches and handles, £450 to your door.
pick up from staffs, £400.
these will be made to order.
there is plenty of room underneath the wings, even if you decide to screw them down, up to the wheel arch can be reached from the back of the vehicle.
