- Jul 24, 2015
Right, next job next problem!
Next job is to refurb the rear drum brakes and replace pads. Unfortunately I can't get the drum off. I have released the hand brake and removed that little screw, and there is a bit of movement but I can't remove the drum. I have tried to use the M8 holes but the rust has got to them and they have rounded so no use.
Any thoughts? What is inside binding, presumably the brake shoes? Is there any way of releasing them from the outside?
ps. The brake hoses are being replaced at the moment so there is no pressure in the brake system to make the brake shoes stick.
Any thoughts much appreciated.
N
N
