Thanks Flint are those the actual mounting points welded to the chassis?Toyota should be able to supply them, not sure if these are what you mean, but if it's the rear body mounts, the parts numbers listed are 51709-60050 (rh) and 51706-60040.
Edit: these are for a 95, worth checking in case swb is different.
