REAR UNDERSLUNG SPARE WHEEL
Graham
I am in uk
Mar 22, 2010
3,921
149
63
Warrington, Cheshire
Hello all,
has any one retro fitted an 'under-slung' spare wheel to the 120 series.
I looked under mine a few times, and there seems to be a fuel return 'cooler' pounted in the way.
So if I try to get a spare in the location, it might hit the diesel cooler what go's back into the tank.
What shall I do ?
Graham
Nuclear Chicken
403
4
38
Norn Iron
Tricky enough to do I'd say Graham. The 'winch' mechanism that winds it up and down would have to be fitted and from memory, in mine, this is welded to the chassis etc etc. Not impossible I suspect but likely more trouble than it's worth. Not sure about fuel lines and stuff and, again from memory, the wheel well area undermeath in mine is pretty much clear.
Graham
I am in uk
Mar 22, 2010
3,921
149
63
Hello,
I may just be tempted to use some 8mm screwed rod, and through the floor for 2 upper bars, which will stop the spare wheel from going too high, and hitting the diesel return cooler.
then, use 2 similar lower bars, to hold the weight of the spare, and use some more 8mm screw rod, to effectively clamp the spare between the lower 2 bars, and the upper 2 bars.
OK, will be a struggle to get it up in the first place, but, this wheel would be 'second in line ' for the spare.
ideas ?
Graham
TonyP
Super Moderator
I am in uk
Feb 25, 2010
3,236
545
113
Goffs Oak
Well I guess it depends on what you are going to do with the vehicle. Would it not be easier to stick the spare on a roof rack?
AdBlock Detected
