Remote switch
Think of the controls for boats with outboard motors and controls at
the front of them - they usually have two controls, one for
forward/reverse and one for acceleration.
You basically want to mimic the forward/reverse setup what switches the
lever on the outboard between forward-neutral-reverse.
All you need it a rotary switch with a lever or wheel on it and then
the cable setup above.
Mobile: 07971 540362
Skype: julianvoelcker
1994 HDJ80, 2.5" OME Lift
Try your local Model shop. Model aircraft use a nylon sheaved rod system you
can both pull and push. With very little expansion or compression.
HTH
Rob
Roman
Forgive me but the start of this thread is on another computer...
Can you just remind me why you needed this?
HDJ81 with all the usual blah blah
On 29/6/06 22:22, "Roman" <[Email address removed]> wrote:
Jeremy Llewellyn-Jones
Mob: 07831 458 793
