Running an 80 with free wheel hubs (long)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 Guys
Could someone explain how you get better fuel economy from disconecting the front hubs.drive shaft etc.
I would have thought that you would use the same or more because you are now driving the same weight vehicle with only one axle drive now.
Would this not require a little more power to it to move what the original two exels were moving to begin with.
How could you possible test this set up without the use of a race track testing centre because all it would take on a normal road is one more or less braking or acelleration and the figures would be off.
Or naybe im way off.
cheers
john 92HDJ 80 1HDT
john byrne wrote:
The amount of energy needed to move the car will not change when
converting from 4wd to 2wd . The idea is that when just "half" the
drive-chain is rotating only "half" of the energy that is lost to.
friction in the drive-chain is "saved"
I'm no scientist, but I'm quite sure that you don't need more energy to
move the car when running as 2wd, but how much is saved I just don't know.
Well.. people that have done it, does say that they get better
fuel-economy .. some say around 10-15% .. but I don't know..
My 80 was born a 4x4 and i think I'll keep it that way ;)
Michael Thorsager, Denmark, http://gallery.vx80.dk
1997 VX80, 2.5" OME (and some other stuff)
John
it will be too much work and costs to do HDJ80 2wd-it just doesn't make
sense.
if you wish so buy J7 series...
I think that permanent AWD has undisputable advantages...
cheers
Lubo
Similar threads
