Qua-patet-orbis
- Jan 9, 2012
Hello everyone,
Since a few months I've got infected with "The landcruiser virus" I had a lot of questions but after a while you learn. I registered at a Dutch forum but not all of my questions are answered so here they come
I've bought a HZJ75 pickup '92 with a very good running 1hz engine. The strange thing about it is that this engine came without powersteering. The previous owner build in a powersteeringpump from a chevy. It works fine but I want to install AC but because of this pump the original compressor cannot be installed. I live in Aruba an it's very hard to find parts overhere. so when I went on a hollyday in the Netherlands I bought a secondhand original powersteeringpump. Back in Aruba I tried to install the pump but the place were the pump has to come is closed I can see 2 hole's without tread and the place were the gearingwheel should go trough. I can buy a new plate with a hole so the pump can be installed but I don't know if that's it. Is it plug and play or are there more parts needed inside? Does anybody know? I want to place a new timingbelt next week so if it's just plug and play I will consider to buy a new plate or let somebody drill a hole and make thread.
I also own a FJ70 with a 3F engine. I was told that the front axle is heavy duty and stronger than the one under te hzj75. The axle of the FJ70 is round and the one of the HZJ75 is square. Is it true that one is stronger than the other and will it fit?
Than I also own a FJ75 pickup, once imported from Venezuela. This car also has a frontaxle with a square shape. Because I broke my leafspring I took one from this car. I'm going to overhaul my car so if this axle is the same as the one of the HZJ75 I will use that one. I already took it of because I broke the leafsprings of the HZJ
When I bought the Hzj75 it came with an original extended bumper and a winch. I took it of, sandblasted, coated and painted all the parts. The winch also needs maintainance but toyota doesn't sell overhaul kits for their own winches. Does anyone know where I can buy this?
I hope to get some answers! greets
