Robert wrote...
My suspicion is that it has some thing
to do with the dye fooling the pump into thinking there was freon in the
system. What do you guys think?
SNIP
Robert, its quite a different smell when that clutch goes isn't it ? )
After my first time the next time I smelt it when driving my 4 Runner I had
the knife in my hand when I left the cab ready to cut the belt. I also had
it seize on my 80 just once too.
I am used to using Toys in hot climates where the aircon does get a lot of
hammer. So have seen plenty of systems refilled. So please do not forget
that the pump does not just circulate gas and dye, otherwise it would seize
immediately. The fitter should also put a specified quantity of lubricant
(usually a synthetic type) into the system before the dye and then finally
the gas.
So first, ask yourself if you remember seeing him put the lubricant in
before the dye and gas. But systems are always filled with dye right from
new and then whenever serviced - in my experience anyway.
So, suspect lack of lube, the dye is innocent !
jon
Linslade Beds: Iskele Cyprus.
Driving various Toys
__________ Information from ESET Smart Security, version of virus signature database 4361 (20090823) __________
The message was checked by ESET Smart Security.
http://www.eset.com
Further Info: http://www.landcruisers.info/
SNIP
the gas.
jon
http://www.eset.com
