MisterCruiser
- May 28, 2014
Attached pic Arghhhh!!!
I changed all the oils in my Cruiser a good while ago and ran into trouble with the Transfer box drain bolt, so I left it altogether. Decided to set about trying it again now whilst off on the Christmas break and its not going well at all.
Why they cant put a normal bolt on these things I don't know, but then again the stupid bolts they use when they do decide to use a normal bolt is'nt much better, they're a half skinny head on them and they rust and fall in on themselves and they're half rounded by rust and wear before you even go near them
Anyway, its a Hex 12 allen stud for this drain bolt, the inside edges were all rounded so I grinded down and hammered in a Hex 14 stud and tried the impact gun after I heated it a bit as well but that just rounded it out more to a complete circle.
I tried cutting a little slot into the edge of the bolt and hammering with a punch but this didnt work either and was afraid to keep going this method as it could end up damaging the bolt making it leak and still stuck.
Anyone got a suggestion as how best to proceed from here, the heat I used was a turbo propane gun, didnt get it orange like a oxy/acy torch would so maybe the oxy/acy heat and a punch is the next step??
Or maybe welding the allen stud into the bung would be a good idea, anyone know if the allen stud material will weld??
Feckin allen bolts
Feckin allen bolts
