Ok, for those still awake, or remotely interested, I got the truck back today
Firstly, I’m eternally grateful to
@chapel gate for his attention, assistance, advice and offers of parts in this regard. If it wasn’t for me living in Eastern Europe, I would have taken full advantage of several lucrative offers of new parts, however the shipping/import made it evens, when I priced stuff here. Anyway, is seems he’s much more clued up on LCs than many of the “experts” and with his advice, I was able to guide my service garage as to what needed doing.
They installed the “upgrade” into my 80 steering box, being the 105 sector shaft and matching seals and Pitman arm. The service was dubious at first, but soon realized that it would work!
The 105 shaft is thicker at the spline, so less likely to be twisted by impact, than the standard 80 shaft.
They also agreed with me about the steering stops on the axle, they are there to protect the steering box against being forced beyond its limits, when a wheel is hit by a rock or whatever, slamming the steering wheel to one extreme or the other.
In setting the steering box to center, and likewise the steering link bar from the Pitman arm, they found that the number of turns left was not equal to the number of turns right.
This was due to the axle not being central to the chassis rails.
I know this isn’t a big deal, it’s not uncommon in lifted trucks for the Panhard rod to pull the axle over. I didn’t realize, but mine is off centre by just over an inch, so I’m lashing out on an adjustable one, so as to get it central.
They set up the stops at the axle so they now limit the steer angle just before the box gets to its limit, so this will reduce the chances of reoccurrence.
Lesson learned!
They’re also exploring the solution to overcome the track arm fouling the diff casing on full lock.
Iron Man do a kit, so when they find it, I’ll be having a good look at what it does and how, to see if it’s suitable to resolve the issue.
They also replaced a leaking flexi-hose in the power steering line, so no more dampness in that area under the pump!
So, for now, I have a dry truck again, I hate leaks, and the steering is spot on!
Thanks again
@chapel gate, your advice was priceless!
BTW, the welder guy put some reinforcement on the Panhard rod mount, but the welding is not as pretty as his work on the cracks. Not to worry, it’s secure, but the welding is a bit gobby. I can live with it though, it’s all strong stuff.
To be continued....
