MisterCruiser
- May 28, 2014
So I screwed the sunroof back together and I don't know whether as a result of having it apart or the fact I sprayed it all with WD40, but I now have a sunroof that not just tilts, but also slides back now too. It definitely would not do that previously, to get it to slide back you just keep the open button held down, I had been doing this previously anyway thinking the tilt should open higher. So anyway, with it slid back, there's still no sign of any drain tubes, or drain holes. I'll have to look into the idea posted by Shayne above, not sure how to do that though, I'll have to have a bit of a google and a read, be handy if that breather valve seal thing could be installed.
Also, I repaired the wiring to my centre interior light above the head rests. The light works properly when the switch is in the "door" position. ie: comes on with doors open, goes off with door closed. However, with doors closed and I flip it to the "On" position, it doesn't light. Is this a dodgey switch or is there anything else that could affect the "on" feature of the light?
Also, does anyone know where to buy the sound deadening / insulation material that is stuck to the underside of the roof in between the head lining? Some of mine is a bit disintegrating, wouldn't mind replacing it.
