Ok so the Rear lights do not work (just the main night time lights).
What I have done:
Checked fuse (10 amp 3rd from the top Rbs column) - ok
Checked all fuses in fuse box - ok
Removed light clusters - both sides
Checked all bulbs - ok
Checked volt reading on cables to both clusters - 0.00 (front lights were in)
Checked by reading across fuse points (removed fuse) - 12v Approx (front lights were on)
Ran cable from -ve side of battery and pugged light cluster in to see if return / earth problem - no lights
Ran cable from +ve side of battery and plugged in light cluster to see if supply side problem - got lights. So I know it's the positive side somewhere between the fuse box and the lights.
Is there a relay somewhere that I can seek to bypass (to test)
Any other advice?
Thanks in advance
What I have done:
Any other advice?
Thanks in advance
