Thank God for.............
Mark01
High security sliding side windows.
The central locking decided to play me up today and locked the car with the keys in.:x
Luckily for me I managed to open the side windows and reach the boot handle on the inside.
All the way home the car was trying to lock its self.
Will have to add this to the list of things to look at when I have a bit of time now.
Cheers mark
Sorted this now by taking the door switch out and giving it all a good clean up. The only problem i have now is when i use the key to unlock the drivers door, only the drivers door unlocks, but all locks and unlocks well on the button.
Could this be a problem with the control box or do i need to look at the loom in the door?
Anybody had this problem before?
Cheers, Mark
Might it be the switch in the drivers door if that's what you've been tinkering with? It might be worth having the door card off again and checking the switch on the back of the key barrel is working with a multimeter.
Thanks Jon, I will check that tomorrow if it stops raining here.
Cheers, Mark
