The most expensive secondhand Land Cruiser
Mal Eade
This was advertised on Google and sold for £149,000 and it was second hand
2004 Toyota Land Cruiser LC 105 Level B-6 Armored SUV
Serial Number : JTEC01J901014046
The armour process has been integrated after the base vehicle production, without changing the exterior appearance. The armour is engineered in such a way that all gaps between the main body of the vehicles and the doors are overlapped and fitted with to prevent foreign projectiles or splinters from entering the passenger compartment.
Materials :
All armouring materials utilized such as steel, aramid and fibreglass have been ballistically tested by independent European authorities. Test reports cans be presented upon request. However complete protection is not possible for reasons of design and modern weapon technology.
Opaque areas :
All opaque areas including the roof are protected against soft core projectiles fired with the following and all lesser weapons at 90° and 45° (roof) impact angle in accordance with the CEN
Calibre 7.62 x 39 mm, FJ/PB/SC, AK 47, (Kalashnikov) OBR-43 PS
Calibre 5.45 x 39.5 mm, AP,FJ/PB/SCP, AKS 74, (Kalashnikov) OBR-74
Calibre 5.56 x 45 mm, FJ/PB/SCP, US rifle M16 A2,SS-109/M-855
Calibre 7.62 x 51 mm, FJ/PB/SC, “FAL”/”LAR” Nato rifle.
Transparent areas :
All transparent areas are protected against soft core projectiles fired with the following and all lesser weapons at 90° impact in accordance with the CEN.
Floor :
The floor of the vehicle is designed in such a way that it will defeat the following hand grenades and all lesser explosives.
- Two DM 51 (German Norm) per sqm detonated simultaneously.
Vehicle Specifications
Base vehicle Toyota Land Cruiser STD, station wagon, off-road-vehicle, new, LHD LWB, 5 doors
Model code HZI105-GCMRS; For use under extreme climatic and physical conditions
Engine model 1 HZ-4164cc, Diesel 6 cylinders
Output 129 hp / 96 kw
Cubic capacity 4.164 cc
Transmission manual five gear transmission
Colour White
Interior grey seats / cloth interior surrounding
Seats 2 + 3 + x 2 seat rear parallel bench
Dimensions and Weights
Length 4.890 mm
Height 1.920 mm
Width 1.940 mm
Wheelbase 2.850 mm
Axle ground clearance 200 mm
Suspension and braking system
The entire suspension system such as shock absorbers and coil springs have been changed to upgrades components to ensure reliability and road safety. The vehicle braking system has been adapted to adhere additional weight constraints that have been applied to the vehicle main body components. Tires and rims have been approved for the higher weight ratio according to APAVE (French Laboratory same TUV in Germany) recommendations and legal requirements. Modifications are carried out in such a way that they pass French type approval.
Included base vehicle equipment
Engine & Chassis
50 liters extra fuel tank
60 amp-hour battery 12V
70 amp alternator 12V
Brake control valve (Load Sensing Pressure Valve)
Cyclone and pre-cleaner type air cleaner
Double fuel filter
Engine oil cooler
Fuel tank and transfer box protection
Full floating rear axle
High altitude compensator
Power assisted steering
Exterior
Exterior rear view mirrors
Front and rear mudguards
Front and rear towing eyes
High/low 2-windshields wipers
Lockable, full size spare wheel mounted under body
Manual free-wheel hubs
Rear step bumper
Rear window wiper
Semi-sealed halogen lamps
Swing-out type back doors
Tubeless tyres
Interior
Adjustable front seats
Air cleaner warning
Air conditioning (no CFC)
Assist grips x 7
Battery volt meter gauge
Cigarette lighter
Digital clock
Door ajar warning
Front and rear door armrest
Front and rear heater vents
Front ashtray
Front center armrest with 3 cup holders
Front head rest x 2
Front seat belts x, three-point on out board seats
Fuel filter warning with buzzer
Fuel gauge
Fuel level warning light
Fuel lid opener switch (keyless)
Heater control ,panel (dial type)
Interior light
Interior rear view mirror (day & night)
Lockable glove box
Odometer (digital)
Oil pressure gauge
Parking brake warning light
Part time transfer lever
Pre-wiring for radio cassette including 2 speakers and manua l antenna
Rear door child protection locks
Rear Headrest x 2
Rear two-seater parallel bench seats in luggage area
Rear seatbelts x 3, three point on outboard seats, two point on the center seat
Seat belt warningSide defroster vents
Speedometer Km/h
Steering column - tilt & collapsible
Steering wheel lock
Sub fuel gauge for second tank
Sun visor x 2
Tachometer – Rev. Counter (rpm)
Timing belt replacement warning light
Trip meter (digital)
Vinyl floor covering
Water temperature gauge
Including accessories
Operator’s manual
Keys : one + two reserve
Touch up paint
Including safety options
Vehicle jack
First Aid kit
Road side warning triangle
Essential tool box consisting of assorted tools according to CEN
Included security equipment:
Alarm siren x 3 tone
In combination with the vehicle intercom and PA system, the alarm siren can be used in the
event of an emergency situation. Three individual loud acoustic tones can be utilised for each separate incident. As a security feature the alarm siren can also be used to draw attention if vehicle occupants are subjected to a potential violent/threatening situation.
Anti-explosion exhaust insert
The exhaust insert will prevent the appliance of improvised explosive devices (IED’s) from
being inserted into the vehicle exhaust system either making the vehicle non-mobile or preventing the vehicle from accelerating with the full power. This is an essential security precaution.
Central door locking system
All five doors are centrally lockable by remote control for easy access.
Battery additional support (Back up)
An additional support battery is installed in the event of the vehicle main battery not
operating on full load ; or when auxiliary electrical equipment is being used. The battery is charged by a diode controlled system and its capacity is constantly controlled. If the main battery is flat or develops a defect the second battery relay switch can be operated by the driver without having to leave the confines of the cab.
Battery armour protection x 2
Both batteries, main and support, are protected within a specially armoured box within the
engine compartment to protect them against projectiles and splinters. Both armoured boxes can be easily removed in quick time for routine maintenance and battery removal.
Engine fire suppressant system
Fire suppressant cartridge is mounted in the vehicle front engine compartment. In the event
of a fire the suppressant system can be activated via easy accessible and recognisable switch from the center console by the driver.
Hinges reinforced
All original OEM door hinges have been replaced with specially designed reinforced
strengthened heavy duty door hinges. These hinges will hold the additional opaque and transparent armour features that are incorporated into the vehicle’s doors.
Intercom system
Intercom system enables vehicle passengers to conduct a two-way communication to persons outside the vehicle. An important security feature eliminating the necessity to wind down window or open up doors at vehicle check points etc.
Protected fuel tank
Fuel tank is completely armoured according to the specification with level CEN B6. Armoured steel will protect fuel tank against the effects of explosives device projectiles being detonated under the vehicle.
Protected vehicle management system (Black box)
As an added precaution, the vehicle management system black box, is also protected with
armoured steel plating to protect it against splinters and projectiles. Many important vehicle
functions are electrically controlled by this piece of equipment.
Run-Flat tire system (inserts)
In the event of vehicle receiving a puncture, blo w-out or having deflated tyres the Run-flat
system will allow the vehicle to continue driving under controlled conditions for 15 km at 50 km/h.
Rotating flashing beacon / spot light connector
Built into the roof of the vehicle is a dual purpose electrical connector. This provision can be
used for the appliance of an emergency rotating flashing beacon, or if it required, a roof mounted remote/manual spot light. The connector can also used as a power source for emergency flashing light bars.
Tails lights and “Kill switch”
As a security precaution aid, an additional interactive “Kill switch” will enable the vehicle driver to kill all the vehicle’s light is one easy action. This function enables the vehicle passengers to exit and enter the vehicle without interior / Exterior lights from going on, thus drawing unwanted attention at night time. In the event of the vehicle being followed or chased a night time, the rear license plate lights and brake lights can be extinguished.
Telephone / Communication preparation cable
Pre-wiring has been laid throughout the vehicle to assist further instalment of communication equipment for on board telephone, radio, GSM communication.
Vehicle suspension stabilising bars
The regular standard OEM Toyota Land Cruiser suspension has been replaced with a more robust heavy duty hard wearing coil system to withstand the additional substantial body armour weight. The additional weight shift and pressure upon this suspension system when a vehicle negotiates a particularly deep pot hole can lead to the situation where the suspension coils do not recover there correct positioning leaving the vehicle in a sunk down leaning position. The adapted suspension stabilising bars will prevent this occurrence from happening. OEM comfort standards are maintained with this feature.
Cloth seating
Seat covering from vinyl to cloth on Toyota 105 model for all x 4 seats. Cloth covering not
only enhances the appearance of the vehicle interior, it also adds to the passenger comfort in hot and humid climates, as well as cold.
Terms and Conditions of Business
SOLD SOLD SOLD SOLD
Priced at $149,000 (USD)
+ $13,000 (USD)/pre-paid shipping (FOB Amman, Jordan)
AND A COUPLE OF OTHERS
Andrew Prince
They could have just bought an 80 for the same level of toughness and protection :mrgreen:
Ecky Thump
can you imagine the weight of it?
It would just sink if you took it over Strata Florida :lol:
