W.G. Bigelow
- Jan 26, 2023
All,
I have noticed a recent “rattle” that has developed after a new exhaust system install. It occurs sometimes when driving, going over bumps etc but it is not consistent. It is really noticeable when the engine is shut off. It is not the exhaust itself but somewhere internal inside the cabin. I have removed the rear carpeting behind the second row seats, also any loose equipment (bottle jack, tools, jumper cables etc..) I removed the inspection panels on the lower door (split rear doors). One of the latch operation arms for the lower door is quite loose but not sure if it’s the culprit. There is a speaker on the right rear panel at the back that I think has an amplifier of some sort mounted below it inside the panel. I haven’t had anyone stand outside at the back during engine shutdown.
Could it be a mounting bracket of some sort that is behind one of the rear panels?
Any and all ideas welcome.
Thanks.
Thanks.
