So I have had this problem on and off for about 4 months but it has got much worse recently. Basically steering is quite tight when turning either left or right. Takes some effort.
When it first started I changed the power steering fluid as is was definitely past it's best but this made no difference. It then went for it's MOT which it failed due to a binding caliper, so I changed both front's and this seemed to fix the steering issue, so I thought good thing.
Sadly last two weeks it has got much worse. So today I took another look and I noticed that the OS track rod end was leaking from the boot, so I have disconnected both left and right track rod ends, but when turning the steering it still feels a both lumpy/notchy.
I will change the track rod ends, as these seem relatively cheep. I have found some from RoughTrax which are a Delphi Lockheed brand Link, does anyone know if these are any good?
Some pics, cause we all like pics
I do fear that the steering rack has a problem, but I really don't want to be removing that.
I welcome any suggestions as to what may be the problem as I am good and hitting things with hammers, but hopeless at diagnosing any suspension or steering issues.
For reference, my 120 is 13 years old with 120k miles on it.
