Check RoughTrax stock to see if you can get the parts Individually... Wiper seal Kit, Then buy the steering Bearings, Then a couple of Inner axle seals, Karsons Double Front Swivel Hub Seal & Gasket Kit - [Leaving Land Cruiser Club].. Another diff is an expensive option, You will still have to do the job of wiper seals bearings etc etc, The same job as you planning to do on the existing axle.... Where are you in Surrey
I’m in Walton on Thames.
What would be the best way to go?, do the knuckles and inner axle seals etc first then get the diff done at a specialist?.
I’m not too sure how the diff gets removed on solid axle vehicles as it’s my first one.
