I can use this bed when I am alone in the car, or the co-driver can sleep and I can drive. So in actual fact, we can drive 23hrs out of 24.
Fitted the left rear hatch.
Now for the right hand side.
The little frame, between the latches, is the strut on the back so that it is stable and does not scratch the car.
I used a 1,6mm sheet for the table. So I added 2 x alu angles along the bottom to make it strong enough.
Just the right height to be practical.
As you can see, it stands slightly proud of the spats. Nothing but that little s/steel frame keeps it away and keeps it stable.
Tomorrow I will do the box that must go on the inside, so I can access it from the outside.
