Dan_the_drifter
- Oct 4, 2018
Only skim read through but if you have noticed a lot of carbon in the intake cross over pipe you definitely want to pull the intake manifold, take a look at my thread and you will see how much was in mine at around 225k. Good luck, hope it works well tomorrow, here's the link:
Edit: Also from my own turbo experience, I am a mechanic by trade, if the gate was stuck shut (as you show) it should have pulled like mad unless it was in a limp home mode. Normally though each time you turn it off and on it would reset so it should have pulled well, hit boost cut at whatever pressure then put the light on and lost all power. Strange that you didn't have full beans each time you came to it from a fresh start. The flapper being shut means your getting as much boost as it will make and not dumping any, if for any reason the actuator doesn't resolve your problem get a boost gauge on there and check what its reaching. You could have an open EGR or bad boost leak.
100 series 4.2TD GX manual from the southwest UK
Hi, I put a post up in the Introduce Yourself section: https://www.landcruiserclub.net/community/threads/hi-from-the-southwest-new-to-me-100-series-amazon-owner.150851/ Nice to get so many friendly responses, been on many other forums and this seems like a good place to hang out :thumbup: I...
