Just noticed oil is leaking from where the rear prop-shaft joins both the gearbox and the rear diff. I assume there are some sort of seals in there... Is it a simple enough job to trust a local garage to do?
Yip, got the rear transfer case extension leak too! I have got a replacement bearing (apparently the leak is often a sign that all is not well with the bearing) and the oil seal. Unfortunately it means taking the whole t/case extension housing off etc. so not a 10 minute job. Hence i have not got round to itLorin said:Just noticed oil is leaking from where the rear prop-shaft joins both the gearbox...
Had a look under the LC today and it seemed a bit oily, 3 seals (front and rear diff + front TC) are sweaty but the rear TC seal is leaking again all over the awesome Gav PlateAndrew Prince said:I believe Rob has done this exercise(without doing the bearing)
Sorry to hear this Rob. I know that when mine went it was all breather related...... Hope you get it sorted.Rob said:Had a look under the LC today and it seemed a bit oily, 3 seals (front and rear diff + front TC) are sweaty but the rear TC seal is leaking again.....
