{tyres] loading] [80]
Hi guys
I know I have asked this before and Roman was kind enough to send me a book
on the subject, but will a 12.5 tyre fit on the 15 inch x 8 rim or not. I
know if the tyre is too wide it will cause driving problems which I do not
want at all. I just want to go to 33s but it seems they are nearly all in
12.5 wide which I dont need and it would mean over two inches overlap each
side of the rim. The info Roman sent me said it should only be a 9 or 9 and
a half inch tyre for the 8 inch rim, but sure it already has a 10.5 on it.
I was tyring to see what the load is that can be carried in the rear of the
cruiser but it does not or I cant find it in the manual any body an idea.
John
On 6/15/05, john byrne <[Email address removed]> wrote:
ok
t
h
nd
he
John,
I'm not sure what you refer to as 12.5 tyre and how you used the
calculator, but when you enter the values for 33 in diameter tyres
(e.g. 255/85/16) in the calculator called "An ideal rim-width
calculator" , the suitable rim width given is between 7 and 8.5 inch.
For 265/85/15 tyres (32.74 inch dia) it will be 7.5 to 9 inch.
Another useful tyre size calculator is here:
http://www.tyresave.co.uk/tyresize.html
Rgds,
Roman (London, UK)
'92 HDJ80
