upper tailgate
Gary Mead
does anybody know for sure if the upper tailgate on an import 80 is the same and will fit on to a uk spec car?im thinking it should fit but you never can be sure?
thanks folks
It'll be the same - only difference might be the mounts for a rear swing out carrier for the spare wheel. The upper tailgate might have a reinforced mounting for the carrier that a UK spec probably wouldn't have. Other than that, the dimensions etc will be identical!
Cheers,
Upper tailgate is the same, the spare wheel mounts are only on the lower and the side of the rear wing as far as I remember.
