Way to go!
As an aside, I recently replaced the timing belt and associated components i.e. tensioner, spring, retainer ect. The work was done over a few weeks and the engine had not been run for months. When I finally got the batteries in last week I turned the key, the engine fired and cut out after a second or so, I turned the key again and the engine cranked quite fast, it sounded like the belt had snapped and there was no compression!
As I pulled off the cam belt cover (easy access, electric cooling fan), I started thinking about the time gaps between fitting components, had I put the woodruff key in? While the belt back plate was off to replace the turbo coolant pipe, did I turn the camshaft, tighten the bolts in the tensioner ect? All sorts of bad scenarios going through my head.
Checked and double checked the timing marks and all good, gave the air intake a sniff of petrol and the engine fired, and I knew straight away what it was, the fuel stop plunger had stuck closed, with the ignition on I tapped the fuel solenoid with a spanner and was rewarded with a click as the plunger retracted, turned the key and away she went.
Then it occured to me, I have never heard an 80 diesel engine turn over, you flick the key and it fires and runs, they never actually spin over before firing. When spinning without fuel, they really sound like an engine with a broken belt.
Dave
