Can anyone confirm that the rear diff lock needs to be engaged when you remove the rear axle from a vdj79 cruiserthanks David , a mate of mine did his and he said he had trouble getting the axle back in because the splined sleeve dropped down a bit, so i guess if the diff lock was engaged it may hold the sleeve in place better
Must be the same as a 80 series, be loads on here will know for sure if the lock should be on or offCan anyone confirm that the rear diff lock needs to be engaged when you remove the rear axle from a vdj79 cruiser
