Wanted: 80 series towing suspension
MuckyPup
I think my back-end is a bit saggy :shock:
I'm getting a lot of bottoming with heavy towing, which is going to be a real problem soon.
Has anyone got anyhting a bit more heavy duty they've taken off for some reason ?
Don't mind STD, +30% or lifted
WHY
If you tow regularly maybe you should get some stiffer springs, and maybe a set of air bags.
i got some uprated standard height springs from milner and bought some genuine rear shock's from them aswel . . Made a huge difference to the way it towed . .
My brother must have about a 100 pairs of new air bags in his garage,,,,,,,,,,,, if your interested I can PM his number to you.
Gra.
I would suggest the Milner springs and air bag route, has worked well for others that tow.
How much are you towing - if basic small Ifor Williams then Milner springs should be fine - fitted some to an 80 up your way the other day, customer very happy with it.
Hi Gareth,
I've got a set, front & rear of OME springs available, I think they give a 2" or could be 3" lift I can't remember now. They were removed to fit a set of Dobinsons which are a bit softer.
Hmm, lots to think about :think:
Trouble is i'm either empty or towing 3.5 tons
And SWMBO is a shortarse.
Never considered airbags before.........
Does anyone do uprated dampers to go with Milner springs ?
I knew I should've kept clear of forums :lol:
I have been thinking about the same thing myself regarding towing and suspention.
I run with 3.5t alot or emptyish.
I have heard millner springs arnt much cop. That isnt my opinion as i dont know. I just know i wont be buying them. On the 100 i had some of those rubber things and they made a difference.That go between the coils.
I want a small lift but something that will still allow me to tow weight safely.
I dont know the cost from towota for the shocks and springs,maybe worth a call.
Im watching this thread with interest.
Karl
