What spring goes where??
Gary Stockton
Super Moderator
zimbabwe
I'll will be fitting OME851 springs up front over Easter along with my EFS shocks and steering damper (I was given all the springs when I bought the truck, lucky me!!). *The springs are labelled A and B. The B one seems to be slightly taller than than the A spring which goes against the info I have which is to fit the B to the passenger side.*
Surely the taller spring needs to go where there is constant weight - i.e. the driver? *Or am I missing something??
Or is it a case if fit it all and check measurements then swap them around till it's all level??
TIA
The longer is supposed to go on the nearside, to allow for road camber.
They are sided to allow for road camber.
The longer one goes on the passanger side.
