To remove them, don't just pull them!! There is 2 bolts through each wing for each arch.
I know as mine is now archless!!
Paul
Paul
When my wheel bearing failed and the wheel flew into the distance, that did a good removal jobEcky Thump said:Or, hit deep water really really fast and you dont even need to undo the bolts to remove them![]()
Rob said:Paul are you running 285/75/16s on standard offset? If you are do the tyres now stick out beyond the body?
Paul,Paul_Humphreys said:PS, anyone got any 4-6" wide conver belt going spare?![]()
