Whizz off Turbo
Alright guys
Dropped the oild and changed air, oil and fuel filters.
Air filter change well over due.
The Turbo seems to be making a hell of a lot more noise after the
service.
Is this normal? - When I say making noise, I mean there was no noticable
noise from it prior to the service.
Could the new air filter make such a difference?
Any thoughts?
Niall
HDj80 320K km
Niall,
check the connection between the air filter can and the turbo for
leaks. It could be that it is now sucking air past the filter ...
Rgds,
Roman (London, UK)
'92 HDJ80 (auto)
On 10/8/07, Somers Niall <[Email address removed]> wrote:
I have never noticed a difference in Turbo noise after changing an air
filter. If you have changed the oil is the new oil getting to the
turbo bearing?
Clive Marks
Home: +44 1293 514600
Mobile: +44 7821 491897
Crawley, West Sussex, UK.
Cheers Roman
Will check that after work
Definitely something not right.
Niall
Clive
Re> is the new oil getting to the turbo bearing?
How is that checked?
Same oil - 10/40 - castrol
Niall
OK Lads
This turbo whizz is still there.
Checked all inlets, outlets, wires, bits and bobs last nite. Nothing out
of the ordinary.
All I did was change the filters and oil.
Does anyone know if a Louder than usual Turbo Whizz is an indication of
impending turbo trouble - ie bearing failure?
If it does go - can I drive on ok?
Otherwise the vehicle has never run better.
Niall
HDJ 80 320K KM - engine replaced but original Turbo
Is the waste gate operating OK?
Malcolm Bagley
Stafford UK
FJ45 '75 & FJ45 '76
Checked by AVG Free Edition.
Version: 7.5.488 / Virus Database: 269.14.5/1058 - Release Date: 08/10/2007
16:54
Yes this can be the true case, I have lived it my self.
If your turbo is shot then try get one from All Americain Imports. It
is better but only cost 1 500 euro.
Malcolm
RE> Is the waste gate operating OK?
Not sure what/where the waste gate is.....
Niall
Benoit
Strange that it manifested itself after a service though
Niall
SNIP
Niall,
As it is next to impossible to diagnose the fault on the net and the
stakes may be high, I'd suggest taking the LC to a reliable workshop
to give it a once over. It will help you decide on the course of
action, though I still believe it may be a minor thing.
You can travel with a shot turbo, provided it had not caused damage to
pistons first. All you need to do is disconnect it at the inlet
manifold. It normally involves driving without air filter, which in
some instances is still better than not driving at all.
Rgds,
Roman (London, UK)
'92 HDJ80 (auto)
On 10/9/07, Somers Niall <[Email address removed]> wrote:
Roman
Booked it in first thing this morning for a once over this afternoon.
Was hoping to be armed with some info before I went in.
Hopefully it's nothing major.
Niall
Wise move Niall.
You don't want to be dealing with turbo failure/problems if you can avoid it. I(
failed to spot a buggered inner axle oil seal before leaving on our trip to N
Africa and it was an unnecessary delay in Spain, much as I love being in the
mountains of Andalucia. If you see/hear something, best to deal with it asap as
you won't have these resources in the middle of nowhere.
You might have better weather though...
Quoting Somers Niall <[Email address removed]>:
Alright lads
Turbo Whizz sorted!
Pipe off the turbo just loose - couldn't see it even though I checked
several times (at night)
Lesson learned: Service the vehicle in the daylight in future
Thanks for the pointers and help
Vroom vroom!! :-)
Niall
Niall,
Glad you found it! Diagnosing on the net has been taken to a whole
new level! Still, don't give up on a third party inspection for any
other possible problem lurking in the dark.
Rgds,
Roman (London, UK)
'92 HDJ80 (auto)
Roman
Re> Diagnosing on the net has been taken to a whole new level!
You bet. Fair dews to the list
RE> Still, don't give up on a third party inspection for any other
It's the age old problem - finding a third party that knows what they're
looking at!
Ta
Niall
Niall,
There are more LC mechanics at the south coast of France than in the
whole of Britain. If you are taking a boat for Africa from France, I
can give you contact details for a good 4x4 outfit in Perpignan.
Rgds,
Roman (London, UK)
'92 HDJ80 (auto)
Roman
RE> I can give you contact details for a good 4x4 outfit in Perpignan.
Might just do that if I go that route. Would be nice to get the once
over the bits I can't or don't have the time to do myself before hitting
Africa.
Niall
