I have an identical alarm to yours Andy and the same problem after the main batteries have been disconnected.
Cure no-1. Turn ignition on. Close all doors. Press the black button for 15 secs to sync the fob.
If that does not work.
Cure no-2. Disconnect both batteries. Turn ignition on. Connect both batteries.
Your fob battery needs to be new and the fob contacts cleaned and greased. They corrode even when dry. I've had 2 of these alarms now and for some weird reason both had the aerial wound round the box. On my green 80 I unwound the aerial and I can now use the fob from nearly 200 feet away whereas before I had to be almost on top of the car.
Frank
Frank or anyone else!
during my recent engine problems and repairs, The truck had been off the road so long the batteries were very low =, so I disconnected them both and recharged them. Upon re-installing, I've had exactly the same immobiliser problem as described by Andy in the original post, coincidentally we have the same trucks. Well I followed Frank's instructions as quoted and they worked, well cure number 2 did.
Unfortunately tonight, I've had to remove the drivers side battery to allow me to delete the Land Cruiser self-immolation circuit (Inlet heater wiring & relay) upon re-connection of the batteries, its bloody immobilised itself again, this time however Frank's cure number 2 isn't working.
I've tried about 10 cycles and after reconnecting the batteries, if I turn the ignition off the hazard lights start flashing & red immobiliser LED light comes on. If I don't turn the ignition off & go for a start, it will start, but on shutting down, it instantly immobilises itself.
Last time when this worked, when the hazards started flashing, I just used the fob & it locked the truck, then unlocked and all was good, this time, it's not playing ball.
Does anyone have any suggestions? For info, I have the key fob with one black & one red button.
Thanks all.
