I've always been interested in these. One thing that puts me off is having no idea about the quality. So what's the quality like?
They came from Malaysia via ebay so I took a bit of a chance.
Ebay page here:
http://www.ebay.co.uk/itm/281366809268
Quality I would give 9/10 the rear lights are LED tail/brake but normal filament bulbs for indicator and reversing light. They fit perfectly. The front lights are an ok fit on bolt positions, not 100%, but they fit the bodywork apertures nicely.
I did have a couple of issues on one side my LC has had a bit of a knock at some time so the bottom bolt holes didnt quite line up had to redrill the light brackets to suit. The biggest problem I had was with the direction the lights dipped. I wrote to the seller before I purchased asking about RHD and were they ok for this, he assured me they were. So bought them and they were LHD and dipped the wrong way, so pretty annoyed. There is though three screws that allow the reflector to be turned for RHD, but they have to be set during assembly as one of the screws is behind the back case and you cant get to it!
So I had to drill the rear case to be able to unscrew them and move it.
I sealed some grommets in afterwards
I left neutral feedback and the seller has offered to compensate me and was all apologies. Just annoying it should have been done at the factory.
With the wiring I added a small loom in the back of the car connected to the trailer plug so I could have a separate fog light and had to run additional wires for indicators as they are not in the wing light plugs for some strange reason. I also put xenon bulbs in the headlights and they are nice and bright.
So even though it was a bit of hassle I think the end result is worth it, it updates it nicely and looks, I think, pretty cool, which is obviously the most important thing
