At the risk of appearing dumb……. are the plugs to prevent water ingress?
S Springate’s New Member Joined Apr 23, 2020 Messages 46 Country Flag Nov 17, 2023 #41 At the risk of appearing dumb……. are the plugs to prevent water ingress?
R Rob Cowell Well-Known Member Joined Nov 15, 2011 Messages 1,643 Country Flag Nov 17, 2023 #42 Springate’s said: At the risk of appearing dumb……. are the plugs to prevent water ingress? Click to expand... Water shouldnt be too bad because it would run out of the drain holes. I think it’s more like mud which then holds the moisture for much longer.
AndycruiserguyLomas Well-Known Member Supporter Guru Joined Nov 19, 2010 Messages 5,911 Country Flag Nov 18, 2023 #43 Rob Cowell said: If you wanted genuine plugs you can see what is available here https://yadakijat.com/images/api/parts//toyota_2019_07/general/570370J.png Amayama stocks at least some of them (all the ones I looked for) Click to expand... That is most useful.
S Springate’s New Member Joined Apr 23, 2020 Messages 46 Country Flag Nov 18, 2023 #44 Rob Cowell said: Water shouldnt be too bad because it would run out of the drain holes. I think it’s more like mud which then holds the moisture for much longer. Click to expand... Cheers, makes sense
