So, picked up the nice shiny injectors today. Washers and inlet manifold gaskets arrived from Toy and O rings from eBay. Managed to change the inlet manifold gaskets without fully removing the inlet manifold. Removed all the studs, cleaned the inlet faces both sides with some clean rag around a paint scraper, drenched in brake cleaner twice then dry for a third time. Then put a smear of RTV sealant both sides and slipped them in. Managed to lose two studs down the side of the engine. Found one!! Got the injector holes cleaned with rolled up half sheet of aluminium oxide paper and a very good scrape with a screwdriver and vacuumed and blew them out. Fitted the injectors and everything else. Had to prime the system with quite a lot of pumps (wasn't expecting this- could this be an indication of something, as I expected the fuel to stay put not leak back).
Started it up after much cranking. And……
Runs nicely but, still vibrates!!!!!
Bugger!!!
So, filter in pump?
Or has cr@p got in the lines and gone straight back into the injectors?
Now, while cranking, there was unevenness in the sound. So, I think I will do the electrical compression test with my pal's scope.
I have now got the acrid exhaust back so the injectors did need a service. And I've done my weeping gaskets. So I'm only going to sulk for half an hour. [emoji22][emoji22][emoji22][emoji37][emoji36]
